Salta al contenuto principale
APEX AP-GS918 Battery Replacement
Cosa ti serve
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, immagine 1 di 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, immagine 2 di 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: passo 1, immagine 3 di 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    Chiedi a FixBot
    Aggiungi Commento
  2. APEX AP-GS918 Battery Replacement: passo 2, immagine 1 di 3 APEX AP-GS918 Battery Replacement: passo 2, immagine 2 di 3 APEX AP-GS918 Battery Replacement: passo 2, immagine 3 di 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    Chiedi a FixBot
    Aggiungi Commento
  3. APEX AP-GS918 Battery Replacement: passo 3, immagine 1 di 2 APEX AP-GS918 Battery Replacement: passo 3, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  4. APEX AP-GS918 Battery Replacement, Battery: passo 4, immagine 1 di 2 APEX AP-GS918 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Begin removing the black tape covering the motherboard inside the tablet.
    Chiedi a FixBot
    Aggiungi Commento
  5. APEX AP-GS918 Battery Replacement: passo 5, immagine 1 di 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    Chiedi a FixBot
    Aggiungi Commento
  6. APEX AP-GS918 Battery Replacement: passo 6, immagine 1 di 2 APEX AP-GS918 Battery Replacement: passo 6, immagine 2 di 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 9-1, Leahy Winter 2015 Membro di USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Membri
9 guide realizzate
1Commento della guida
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 939
