Introduzione
This guide walks you through the steps of removing the Electronic Speed Controller (ESC) and Power Distribution Board (PDB) of the 3DR Iris Plus. This part is what communicates commands from the flight controller to the motors, and distributes power to the rest of the drone. As stated in the Troubleshooting Guide, if the drone is powered, but it is not responding, it is possible the ESC/PDB is damaged. This guide requires the use of a soldering iron and a set of screw drivers.
For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Cosa ti serve
Power off the drone by holding down the power button.
Remove the battery by disconnecting it from the main battery connector.
Press the power button again to ensure all electricity is discharged.
If your drone is equipped with it, remove the video transmitter.
Disconnect all cables from the gimbal.
If your drone has neither the gimbal or video transmitter, you can skip this step.
Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
Unscrew the four 4mm screws that hold the board to the central drone assembly using the 2mm Hex screwdriver/key.
Desolder the 12 motor wires.
