Introduzione
按照本指南更换 Sony Playstation 4 上的主板。
主板和光驱是配对的,因此只更换主板会导致设备无法运行。请务必为你的 PS4 型号订购正确配对的光驱和主板,并更换两者。
在开始任何维修之前让你的 PS4断电。
Cosa ti serve
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?查看我们的 论坛 以获取故障排除帮助。
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
Altre 195 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
17 Commenti
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
contacts of the motherboard
You may be talking about capacitors that are critically important for the unit to function.
South30 -
