Salta al contenuto principale
Repair guides and support for SD, miniSD and microSD memory cards used in tablets, phones and cameras.
Remove write protection from SD card
How do I remove write protection from SD card please?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione prescelta
If you look at the SD Card just to the right here you'll see a slider on the left this needs to be up position.
In addition you may need a small piece of tape to cover the right side notch. You do need to be careful here as you don't want the tape to cover the contacts on the other side, nor do you want it to come off inside your reader making a bigger mess!
Punteggio 8
1 Commento:
Many thanks for this, so simple yet saved me having to buy a new SD.
da
Aggiungi la tua risposta
bobcave1 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 29
Tutti i Tempi: 6,170
