Salta al contenuto principale
2,26 o 2,4 GHz / Telaio unibody in plastica bianca
No backlight after lcd replacement
Hello everybody!
I have a problem with my MacBook.
I've replaced the lcd with a new one: when I turn on the Mac, I see a very very soft image on the display.
The back light doesn't work...
Anybody has an idea of what can I do?
Is there any fuse or similar to check?
Thanx in advance for who will answer to my question!
And if you need more information, don't hesitate to tell me! ;-)
Teo
ITALY
ps: sorry for my english, I hope you can understand =)
Update
The correct model is MC207, the one made out of white plastic material.
Is there a fuse to check on the inverter board?
Thanks
Teo
Update
I don't know how to thank you, guys!!
Really, thank you so much for your answers, the fuse was the cause! I've replaced it and the lcd now works perfectly!
You're great!!
Thanks a lot to everybody!
Teo
Questa è una buona domanda?
Punteggio 1
1 Commento
Teo, according to your number you gave us, your computer should have these specs: 2.26 GHz Core 2 Duo (P7550)
Intro Date: October 20, 2009 Disc Date: May 18, 2010
Order No: MC207LL/A Model No: A1342 (EMC 2350*)
Subfamily: Late 2009 Model ID: MacBook6,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
Teo, here is the location of the fuse.
Immagine
The fuse is F9800 which is a 2amp 32 V SMC fuse in a 0402 package.
Punteggio 3
Your generic ID covers 127 different machines over about 6 years. Some of these have LED backlights and controllers /aka fuses. Others have CFL backlights and inverter boards.
If you purchased a used display it may have a bad backlight.
If you indeed have an early model in plastic you could check the inverter boards and cabling. Some of the mid range aluminum models also had TFT screens with CFL backlights but from about 2010 on they started using LED screens.
If there was liquid damage that shorted out the display the problem may be on the logic board not the display, inverter or cables.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Hello such, I need help, MacBook pro A1286 disarmament, to cleanse it, now does not video, not if they could show me where are the fuses to check them please
Punteggio 0
Aggiungi la tua risposta
Teo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 15
Tutti i Tempi: 2,793
