Perché la Ventola del mio Mac mini gira sempre al massimo?
Quando accendo il Mac mini si accende al massimo non so come risolvere cosa può essere
Questa è una buona domanda?
@francescom38552 sounds like you might have a bad sensor. If your Mini encounters a bad sensor, it will automatically run the fans at high speed.
Try a SMC and PRAM reset first
Resetting the System Management Controller (SMC)
To reset power management via the SMC chip:
1. Unplug all cables from computer, including power cord.
2. Wait at least 15 seconds. The SMC reset occurs automatically once the Mac mini has been unplugged from AC power source for several seconds.
3. Plug power cord back in, making sure power button is not being pressed.
4. Reconnect keyboard and mouse to computer.
5. Press power button on back to start up computer.
Resetting the SMC means you will also need to reset the date and time (using the Date & Time pane of System Preferences).
Resetting the Parameter RAM (PRAM)
To reset PRAM,
1. If the computer is on, turn it off.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step 4.
Note: If the keyboard does not have an Option key, use the Alt key instead.
3. Turn on the computer.
4. Press and hold the Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
6. Release the keys.
I would try some monitoring software like TG pro or Macs Fan Control what your sensors report. Of course you can also try to run the Apple Diagnostics. Let us know what this all tells you. It's best if you post a picture of the results with your Question. That way we can hopefully determine if, and what sensor, is giving your Mini trouble.
Translation
sembra che il sensore sia difettoso. Se il Mini incontra un sensore difettoso, farà funzionare automaticamente le ventole ad alta velocità.
Provare prima a resettare SMC e PRAM
Ripristino del controller di gestione del sistema (SMC)
Per ripristinare la gestione dell'alimentazione tramite il chip SMC:
1. Scollegare tutti i cavi dal computer, compreso il cavo di alimentazione.
2. Attendere almeno 15 secondi. Il reset dell'SMC avviene automaticamente una volta che il Mac mini è stato scollegato dalla fonte di alimentazione CA per alcuni secondi.
3. Ricollegare il cavo di alimentazione, assicurandosi che il pulsante di accensione non sia premuto.
4. Ricollegare la tastiera e il mouse al computer.
5. Premere il pulsante di accensione sul retro per avviare il computer.
La reimpostazione dell'SMC comporta la necessità di reimpostare anche la data e l'ora (utilizzando il riquadro Data e ora di Preferenze di Sistema).
Azzeramento della RAM dei parametri (PRAM)
Per reimpostare la PRAM,
1. Se il computer è acceso, spegnerlo.
2. Individuare i seguenti tasti sulla tastiera: Command (Comando), Option (Opzione), P e R. Al punto 4 è necessario tenere premuti questi tasti contemporaneamente.
Nota: se la tastiera non dispone del tasto Opzione, utilizzare il tasto Alt.
3. Accendere il computer.
4. Tenete premuti i tasti Comando-Opzione-P-R.
Importante: è necessario premere questa combinazione di tasti prima che appaia la schermata grigia.
5. Tenere premuti i tasti finché il computer non si riavvia e non si sente per la seconda volta il suono di avvio.
6. Rilasciare i tasti.
Proverei a verificare con un software di monitoraggio come TG pro o Macs Fan Control cosa segnalano i sensori. Naturalmente puoi anche provare a eseguire il programma Apple Diagnostics e farci sapere cosa ti dice tutto questo. È preferibile che pubblichiate un'immagine dei risultati con la vostra domanda. In questo modo potremo determinare se e quale sensore sta dando problemi alla tua Mini.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 26
