Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 Domande Visualizza tutte
Thermal sensor compatibility WD 1TB - Seagate SSHD 1TB
Hi,
I was changing the hd drive of my imac 27" mid 2010 because de original one failed. I bought a Seagate SSHD 1Tb to put instead. I was not able to see which was the original HD until I opened 5 minutes ago. I chose the Seagate because I read about its compatibility with my imac mid 2010. Well, the problem is that the thermal sensor connector (8 pins) does not fit in the Seagate (4 pins). I also read about the OWC kit, is that the only solution for this?
Can anyone help me with this?
thanks!!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I do like that Seagate SSHD drive.
Here's what you need: https://eshop.macsales.com/item/OWC/DIDI...
Punteggio 4
4 Commenti:
Thanks a lot Mayer! I just purchased it.
da
Don't forget the in-line thermal sensor Mayer pointed to!
da
@danj he said he already bought that.
da
@mayer - Just making sure ;-}
da
Aggiungi la tua risposta
Oriol Hurtado sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 534
