Airport Card
2 Risposte Punteggio 0 |
Sensore temperatura con SSD |
1 Risposta Punteggio 1 |
Domanda upgrade GPU e SSD iMac 27" mid 2020 |
1 Risposta Punteggio 0 |
Posso installare due ssd dentro mio iMac? |
installare da zero sistema operativo os |
Ricambi
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Modelli
A1312 Mid 2010 iMac11,3 2.8 GHz, A1312 Mid 2010 iMac11,3 2.93 GHz, A1312 Mid 2010 iMac11,3 3.2 GHz, A1312 Mid 2010 iMac11,3 3.6 GHz
Troubleshooting
There are no troubleshooting guides for the iMac Intel 27" EMC 2390 at this time.
Upgrades
You can cost-effectively upgrade a number of components in the iMac Intel 27" EMC 2390.
- RAM: If your iMac is still running with only the stock RAM, upgrading will provide a dramatic performance boost at minimal cost. Upgrading to the maximum of 16 GB (Four 4 GB chips) provides unmatched performance.
- Hard Drive: 1 TB hard drives came standard with the iMac Intel 27". You can upgrade the drive up to 2 TB.
Identification and Background
You can verify that you have a iMac Intel 27" 2390 by checking the processor information through "About This Mac" in the Apple menu. iMacs tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
The iMac Intel 27" has multiple external and internal differences from 24" iMacs. Externally, the machine features edge-to-edge glass and an aluminum rear bezel. Internally, an LED display, more powerful video processing, and faster processors round out the impressive upgrades. Additionally, the 27" iMacs have the build-to-order option of a Quad Core i5 or i7 processors to give you the most powerful iMac experience yet!
