Is There an alternative to the iOpener
I Dont have an i opener and i was wondering if i could use anything else that does the same exact thing as the iOpener. Thanks
Questa è una buona domanda?
A heating pad or a heat gun. :)
Very, very, very careful use of a heat gun at that!
Yea, always use it on low.
I know this is a bit late ;>)...
If you are a shop and will be doing iPad repairs on a regular basis, then a heated mat station like this is the preferred solution.
However, if this is for a one-off, the these "Magic Bags" work really well. This one is large enough to cover an entire iPad making it perfect for a digitizer replacement and you can use it at home when you have sore muscles.
I used the back of a stoneware plate taken out of the dishwasher after the drying cycle was done. It was quite warm and stayed that way for a long time and did the job fine. Based on previous battery replacement projects, I thought the back of the phone would have to be pried out of attachment fittings on the phone body, but in fact it was mostly held on with glue, so heating and alcohol along with suction as described on this site are the way to go. Also you should purchase the OEM double sticky tape to reassemble the device nicely after the battery replacement.
Great suggestion. We have a few ceramic plates to protect surfaces from hot pots. I will heat one up on my griddle, 140℉ as a starting point, and work from there.
Thanks.
You can follow our guides on using a hair dryer and heat gun, good luck!
Guida
Difficoltà:
Moderato
Guida
Difficoltà:
Moderato
Ultime 24 Ore: 2
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 216
Tutti i Tempi: 10,321
3 Commenti
Thanks and also do i absolutely need an iOpener Or anything to do most repairs
da Zac Cobos
Here is a video on using a heating pad as an iopener - https://www.youtube.com/watch?v=ZIrmxkX8...
da Sebastian Edinger
https://www.amazon.com/dp/B00AZ72MAE/?th... is a larger option, It may take longer in the Microwave.
da Joshua Lopez
