Salta al contenuto principale
Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: passo 2, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: passo 2, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the stylus: passo 2, immagine 3 di 3
    • Push the button at the base of the stylus.
    • The stylus will partially eject.
    • Remove the stylus.
  3. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the right edge: passo 3, immagine 1 di 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  4. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Adhesive information: passo 4, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Adhesive information: passo 4, immagine 2 di 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  5. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  6. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: passo 6, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: passo 6, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the right adhesive: passo 6, immagine 3 di 3
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  7. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the bottom edge: passo 7, immagine 1 di 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  8. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 8, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 8, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 8, immagine 3 di 3
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  9. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the bottom adhesive: passo 9, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the bottom adhesive: passo 9, immagine 2 di 2
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the left edge: passo 10, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  11. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, immagine 3 di 3
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  12. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: passo 12, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: passo 12, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the left adhesive: passo 12, immagine 3 di 3
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  13. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the top edge: passo 13, immagine 1 di 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 14, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 14, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 14, immagine 3 di 3
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  15. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the top adhesive: passo 15, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the top adhesive: passo 15, immagine 2 di 2
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  16. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 16, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 16, immagine 2 di 2
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  17. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the remaining adhesive: passo 17, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the remaining adhesive: passo 17, immagine 2 di 2
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  18. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: passo 18, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: passo 18, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the back cover: passo 18, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: passo 19, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: passo 19, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Slice the adhesive: passo 19, immagine 3 di 3
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  20. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: passo 20, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: passo 20, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: passo 20, immagine 3 di 3
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Identify your screws: passo 21, immagine 1 di 1
    • If you're using the Samsung Self Repair Kit, take a moment to identify your screws and label them accordingly:
    • Label the bag with the most screws and the colored bag #3428.
    • If you're replacing the screen and battery, label the clear bag with two screws #3439.
  22. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the NFC antenna and charging coil: passo 22, immagine 1 di 1
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with the new ones labeled #3428.
  23. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the loudspeaker: passo 23, immagine 1 di 1
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  24. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: passo 24, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: passo 24, immagine 2 di 2
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  25. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 3 di 3
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  26. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: passo 26, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: passo 26, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  27. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the lower 5G mmWave antenna: passo 27, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the lower 5G mmWave antenna: passo 27, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the lower 5G mmWave antenna press connector.
  28. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the lower 5G mmWave antenna: passo 28, immagine 1 di 1
    • Use your Phillips screwdriver to remove the two 3.5 mm-long screws securing the antenna bracket.
  29. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: passo 29, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: passo 29, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the lower 5G mmWave antenna: passo 29, immagine 3 di 3
    Compra
    • Insert the pointed end of your spudger between the lower screw mount of the antenna bracket and the frame.
    • Pry up on the bracket until you can grab it with blunt nose tweezers or your fingers.
    • Remove the lower 5G mmWave antenna.
  30. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: passo 30, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: passo 30, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: passo 30, immagine 3 di 3
    • Before reinstalling the lower 5G mmWave antenna, replace the bracket with a new one. If you don't have a new bracket, skip this step.
    • Remove the antenna and connector from the old bracket.
    • Remove the L-shaped adhesive liner from your new bracket.
    • Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
    • Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
  31. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the upper 5G mmWave antenna: passo 31, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the upper 5G mmWave antenna: passo 31, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the upper 5G mmWave antenna press connector.
  32. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: passo 32, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: passo 32, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: passo 32, immagine 3 di 3
    • Insert the pointed end of your spudger in the gap between the bottom edge of the 5G mmWave antenna and the motherboard.
    • Pry the antenna out of its recess until you can grab it with your fingers or blunt nose tweezers.
    • If the antenna feels stuck, apply a heated iOpener for two minutes to soften the adhesive.
    • Remove the upper 5G mmWave antenna.
  33. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: passo 33, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: passo 33, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: passo 33, immagine 3 di 3
    • Replace the adhesive on the upper 5G mmWave antenna before reinstalling it. If you don't have replacement adhesive, reuse your old one or use custom-cut adhesive.
    • Remove the existing adhesive from the antenna with blunt nose tweezers or your fingers.
    • Remove the clear liner from your new adhesive.
    • Apply the new adhesive to the bottom of the antenna, with its round end farthest from the connector.
    • Remove the green liner from the adhesive before reinstalling the antenna in the frame.
  34. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: passo 34, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: passo 34, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: passo 34, immagine 3 di 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the motherboard.
    • Repeat for the secondary interconnect located to the left of the primary cable.
  35. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: passo 35, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: passo 35, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement: passo 35, immagine 3 di 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the charging board.
    • Repeat for the secondary interconnect cable.
  36. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: passo 36, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: passo 36, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: passo 36, immagine 3 di 3
    • Grab and remove the interconnect cables from the frame.
  37. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the charging board: passo 37, immagine 1 di 1
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  38. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry up the charging board: passo 38, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry up the charging board: passo 38, immagine 2 di 2
    • Insert the pointed end of your spudger under the charging board opposite the USB-C port.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  39. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: passo 39, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: passo 39, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the charging board: passo 39, immagine 3 di 3
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
  40. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the laser AF module: passo 40, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the laser AF module: passo 40, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the laser autofocus module press connector.
  41. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard cover: passo 41, immagine 1 di 1
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the motherboard cover.
  42. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: passo 42, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: passo 42, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover and laser AF module: passo 42, immagine 3 di 3
    • Insert the pointed end of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover and laser AF module.
    • During reassembly, press down on the cover to secure its clips to the frame.
  43. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: passo 43, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: passo 43, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the front-facing camera press connector.
  44. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: passo 44, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: passo 44, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the fingerprint reader press connector.
  45. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: passo 45, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: passo 45, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector.
  46. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: passo 46, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: passo 46, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the stylus' press connector.
  47. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard: passo 47, immagine 1 di 1
    • Use your Phillips screwdriver to remove the 3.5 mm-long screw securing the motherboard.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screw with the new one labeled #3428.
  48. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the motherboard up: passo 48, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the motherboard up: passo 48, immagine 2 di 2
    • Insert the pointed end of your spudger between the top left of the motherboard and the frame.
    • Pry the motherboard up until you can grab it with your fingers.
  49. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: passo 49, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: passo 49, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: passo 49, immagine 3 di 3
    • Grab the motherboard by the left edge and remove it from the frame.
    • Be careful not to catch on any loose cables.
    • During reassembly, be sure the cables are above the motherboard when reinserting it.
  50. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Unfasten the earpiece speaker and vibration motor: passo 50, immagine 1 di 1
    • Use your Phillips screwdriver to remove the two 3.2 mm-long screws securing the earpiece speaker and vibration motor.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with the new ones labeled #3439.
  51. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: passo 51, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: passo 51, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the earpiece speaker and vibration motor: passo 51, immagine 3 di 3
    • Insert the flat end of your spudger underneath the bottom edge of the earpiece speaker and vibration motor.
    • Pry the earpiece speaker and vibration motor up from its recess and remove it.
  52. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Heat the front-facing camera: passo 52, immagine 1 di 1
    • Heat an iOpener and apply it to the top of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  53. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: passo 53, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: passo 53, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: passo 53, immagine 3 di 3
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
    • Use the pointed end of your spudger to pry the front-facing camera from its recess.
    • If the camera doesn't loosen, use your SIM card eject tool to scrape away the epoxy surrounding the camera.
  54. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: passo 54, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: passo 54, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the front-facing camera: passo 54, immagine 3 di 3
    Compra
    • Use a pair of blunt nose tweezers to grab and remove the front-facing camera from its recess.
    • Work slowly to avoid tearing the fragile cable.
  55. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: passo 55, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: passo 55, immagine 2 di 2
    • During reassembly, prepare your new frame for the front-facing camera:
    • Remove the black adhesive liner from the front-facing camera recess.
    • Peel and remove the foam liner from the new frame.
    • This liner isn't necessary for the repair.
  56. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: passo 56, immagine 1 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: passo 56, immagine 2 di 3 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: passo 56, immagine 3 di 3
    • Before installing the front-facing camera in your new frame, apply new adhesives onto the frame and the camera:
    • Remove the two large clear rectangular liners from the adhesive sheet and place the adhesives on the sides of the camera recess.
    • Remove the liner from the main adhesive piece and place it in the center of the camera recess with its pull tab facing the bottom of the frame.
    • Remove any adhesive residue from the front-facing camera module.
    • Remove the liner from the thin piece of adhesive and place it on the top edge of the camera.
  57. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: passo 57, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: passo 57, immagine 2 di 2
    • Install the front-facing camera:
    • Remove all four blue adhesive liners from the camera and the frame.
    • Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
  58. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the display: passo 58, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Disconnect the display: passo 58, immagine 2 di 2
    • Use the pointed end of your spudger to pry up and disconnect the display cable press connector.
  59. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the display cable: passo 59, immagine 1 di 2 Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Remove the display cable: passo 59, immagine 2 di 2
    • Grab and remove the display cable from the frame.
  60. Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: passo 60, immagine 1 di 1
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Conclusione
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Download the Self Repair Assistant on your device and Samsung Self-Repair document (beginning page 11) to perform a battery cycle reset.
Altre 27 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
67.441 Reputazione
453 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.442 Guide realizzate
31 Commenti
What about the adhesive when reassembling? Do I need to apply more? Or, does the original adhesive, reseal itself?
Kenny GuessWhat - Replica
Hi! The Samsung Self Repair kit includes replacement adhesive to seal up the back cover. As mentioned in Step 18, follow this guide to clean your phone and apply the adhesive with an official replacement. If you don't have replacement adhesive, cut your own adhesive using double-sided tape, as described in this guide. Note that water resistance depends on how well you reapply your adhesive.
If you don't have access to either of these options, and your existing adhesive is in great condition, you may temporarily reuse the existing adhesive. I recommend shaping the adhesive exactly how it was before disassembly, and heating it with a heat gun or hair dryer to soften it before installing your back cover. Exercise caution when heating the phone, and follow this guide as a reference for heating your device.
Clay Eickemeyer -
So I have a stupid question but I was told that if you had a different color phone that the Amoled screen had to match the casing of the phone or it would affect the effectiveness of the screen and the calibration. This sounds so incredibly stupid to me but is this true?
Marie Faulkner - Replica
Anything regarding part compatibility is important to us. May I ask where you heard this, and in what context? My initial reaction is that the screens are compatible, since there is no calibration software, anyway. There is only fingerprint sensor calibration.
Clay Eickemeyer -
@cashewclay I'll second what Marie said - I've heard the same when I called one of the authorized samsung repare centers, they said that they have had multiple odd issues when screen mismatched the back of the phone. Agree that it sounds weird.
Elizabeth -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 114
Ultimi 7 Giorni: 695
Ultimi 30 Giorni: 2,515
Tutti i Tempi: 64,269
