AirPort Card
1 Risposta Punteggio 0 |
E' possibile inserire un SSD al posto del lettore CD? MacBook iniz 08 |
2 Risposte Punteggio 1 |
È possibile mettere Windows o Ubuntu come sistema operativo nel Mac |
come si cambia hard disk con ssd |
E' possibile installare scheda wireless BCM94321MC? |
Ricambi
- Cameras (1)
- Case Components (22)
- Display Components (1)
- Fans (2)
- Heat Sinks (4)
- Keyboards (3)
- Kits (7)
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Modelli
A1181 (EMC 2121 MacBook2,1) 1.83 GHz, A1181 (EMC 2121 MacBook2,1) 2 GHz (Late 2006), A1181 (EMC 2121 MacBook2,1) 2 GHz (Mid 2007), A1181 (EMC 2121 MacBook3,1) 2 GHz (Santa Rosa), A1181 (EMC 2139 MacBook2,1) 2.16 GHz, A1181 (EMC 2200 MacBook3,1) 2.2 GHz (Santa Rosa), A1181 (EMC 2242 MacBook4,1) 2.1 GHz (Penryn), A1181 (EMC 2242 MacBook4,1) 2.4 GHz (Penryn), A1181 (EMC 2300 MacBook5,2) 2 GHz (Early 2009), A1181 (EMC 2330 MacBook5,2) 2.13 GHz (Mid 2009)
Troubleshooting
Track down a number of hardware problems using the MacBook troubleshooting guide.
Upgrades
You can cost-effectively upgrade a number of components in the MacBook Core 2 Duo.
- Memory: The MacBook Core 2 Duo shipped with 512 MB or 1 GB of RAM. If your MacBook is still running with only the stock RAM, upgrading will provide a dramatic performance boost at minimal cost. Upgrading to the maximum (3 GB for Core 2 Duo, 4 GB for Santa Rosa or Penryn) can be done very easily.
- Hard Drive: 60, 80, or 120 GB hard drives came standard with the MacBook Core 2 Duo. You can upgrade the drive up to 750 GB.
- Battery: Replacing the battery requires a coin or a flat-edge tool release the battery latch. The battery can be replaced in less than 30 seconds.
- Optical Drive: The standard optical drive shipped with MacBooks is either a Combo Drive or a 4x, 6x, or 8x SuperDrive. The optical drive can easily be upgraded to an 8x SuperDrive.
Identification and Background
You can verify that you have a Core 2 Duo MacBook by checking the processor information through "About This Mac" in the Apple menu. If your computer's case is plastic and "About This Mac" says you have a Core 2 Duo, then you're in the right place. If your computer has a metal case, you could have the MacBook Unibody or MacBook Air.
Use the laptop identification system to help you identify your machine. MacBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
This laptop was an update to the MacBook Core Duo that was introduced six months earlier. It came in two colors: basic white, and optional (and more expensive) black. The same industrial design employed by the MacBook Core Duo was also applied to the Core 2 Duo, as the overall size, shape, and layout of the laptop did not change. As with the original MacBook, this laptop included an iSight camera and used the same MagSafe power connector.
The primary improvements that Apple made in the MacBook Core 2 Duo were the addition of a faster processor, improved AirPort, and a larger RAM maximum capacity.
Tech Specs
Display:
- 13.3-inch (diagonal) glossy widescreen. TFT display with support for millions of colors
Storage:
- 60GB, 80GB, 120GB, 160GB or 200GB Serial ATA hard disk drive
One of the following optical drives:
- 24x slot-loading Combo drive (DVD-ROM/CD-RW)
- Reads DVDs at up to 8x speed
- Writes CD-R discs at up to 24x speed
- Writes CD-RW discs at up to 16x speed
- Reads CDs at up to 24x speed
- 6x slot-loading SuperDrive (DVD+R DL/DVD±RW/CD-RW)
- Writes DVD+R DL (double layer) discs at up to 2.4x speed
- Writes DVD-R and DVD+R discs at up to 6x speed
- Writes DVD-RW and DVD+RW discs at up to 4x speed
- Writes CD-RW discs at up to 10x speed
Processor:
- 1.83GHz with 2MB shared L2 cache or 2.0GHz with 4MB shared L2 cache Intel Core 2 Duo processor
Memory:
- 512MB or 2GB of 667MHz DDR2 SDRAM
Wireless Connectivity:
- Built-in 802.11g Wi-Fi AirPort Extreme wireless networking
- Built-in Bluetooth 2.0 Wireless Technology
Graphics and video:
- Intel GMA 950 graphics processor
- Built-in iSight camera
- Mini-DVI port
Ports:
- One FireWire 400 port (up to 400 Mbps)
- Two USB 2.0 ports (up to 480 Mbps)
- Gigabit Ethernet
Audio:
- Built-in stereo speakers
- Built-in omnidirectional microphone
- Combined optical digital audio input/audio line in (minijack)
- Combined optical digital audio output/headphone out (minijack)
Battery and power:
- 55-watt-hour lithium-polymer battery (with integrated charge indicator LEDs) providing up to 6 hours of battery life (2)
- 60W MagSafe Power Adapter with cable management system
- MagSafe power adapter port
In the box:
- MacBook
- Apple Remote
- 60W MagSafe Power Adapter, AC wall plug, and power cord
- Lithium-polymer battery
- Install/restore DVD
- Printed and electronic documentation
