Salta al contenuto principale
MacBook Core 2 Duo RAM cover replacement
Cosa ti serve
  1. MacBook Core 2 Duo RAM cover replacement, RAM cover: passo 1, immagine 1 di 1
    • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
    • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
    • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
  2. MacBook Core 2 Duo RAM cover replacement: passo 2, immagine 1 di 1
    • Pull the L-shaped RAM cover towards you and remove it from the laptop.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
jp en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Uhucream
Membro da: 10/04/15
797 Reputazione
2 Guide realizzate
Japanese Translators Membro di Japanese Translators
Community
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,399
