Salta al contenuto principale
« Torna a Tutte le Storie
Successful First-time iPhone 6 Battery Replacement
David -
iPhone 6
Immagine Storia
45 minuti
Moderate
Il Mio Problema
The OEM battery had been reduced to less than 30% capacity and Apple refused to service the phone stating this was normal decline in battery life.
La Mia Riparazione
Everything went well, with the one exception that I could not remove one of the 5 screws securing the cover over the display cable. Attempting to unscrew it with the iFixit-supplied screwdriver may have slightly stripped the screw. Ultimately had to remove and replace the battery without fully removing the display, but it all went smoothy after that.
Il Mio Consiglio
Be patient with the battery adhesive. Despite the iFixit instructions I found it MUCH more productive to pull the adhesive only toward the bottom of the unit without moving to either side. You just have to give it time to loosen on its own while applying constant force to maintain tension, but it will come out and you won't have to use an iOpener or a hairdryer.
Immagine iPhone 6 Battery
iPhone 6 Battery
$24.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 4
Tutti i Tempi: 129
