iFixit Opening Picks (Set of 6)
  • iFixit Opening Picks (Set of 6) / New
  • 360°
360
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Spedizione gratuita per ordini superiori a $20
Usa il codice BLUEANDBLACK al checkout
Dettagli Prodotto
Descrizione
Descrizione
Pick your way to repair!
  • 6 very thin opening picks
  • Can be used for prying, sliding, separating, and air guitaring.
  • These picks are especially useful for prying open iPads and other glue-laden devices.
Storie di Riparazione
Scott Cassio's Story Photo #885867
Il Mio Problema
Cracked front panel assembly
La Mia Riparazione
The repair is pretty straight forward until the conclusion which states, 'But first ensure to place a narrow piece of tape over the copper/silver at the bottom of the digitizer to the left and right of the home button.'
Since there was no tape in those areas when I took . . .
Il Mio Problema
Old battery couldn't hold a charge for long.
La Mia Riparazione
Your tools made getting into the case easy. The only problem was getting the old battery out... Too much original glue!
The supplied tools made the job much easier.
Il Mio Consiglio
Don't try to open the case with your fingernails!
Il Mio Problema
Spider web screen
La Mia Riparazione
Repair went very well instructions were plain enough was a little nervous of crushing a connector after the first one was in it was smooth sailing about an hour to do
Il Mio Consiglio
Go slow take your time and follow instrutions
Il Mio Problema
Accidentally dropped my phone right on the back.
La Mia Riparazione
With a heat gun on low the glue softened up very easily. Needed something sharper and thinner to get under the glass but once I did it peeled off easily. Removed all the old glue with a knife to hopefully retail some water resistance.
Il Mio Consiglio
Use the heatgun . . .
Il Mio Problema
Screen was badly cracked after bing dropped on corner of iPad.
La Mia Riparazione
Repair went smoothly. No major issues but needed another tool to make it really work.
Il Mio Consiglio
Need to stay patient as it's tedious work getting the screen off. After that it's pretty easy. The plastic tool to pry open the screen from the edge isn' . . .
Il Mio Problema
My wife's phone. She cracked her LCD screen
La Mia Riparazione
The "Ifixit" video manual was to the point and quite accurate except a couple of things. On this particular phone the original adhesive refused to let go after heating the chassis several times. The iSclack was not strong enough to lift the rear cover loos . . .
Il Mio Problema
My power switch was stuck. I bought a spare part off eBay.
La Mia Riparazione
You guys rated the fixability a "1" and I completely agree. What a pain. I was able to get the switch replaced and the unit works except that when I was using the picks I pushed one in too far and it broke the digitizer membrane on the top-le . . .
Il Mio Problema
Cracked Screen
La Mia Riparazione
Great!
Il Mio Consiglio
Becareful where you order your screens. I had to do this twice!!
Il Mio Problema
Kindle would not charge unless you did the wire dance ( moved it all over) until you find the spot that if you're lucky will charge after you sit it down . Got to the point that I had to do it without moving the Kindle.
La Mia Riparazione
Very well, you just have to pay attention to details.
Il Mio Consiglio
Have a clean surface and all . . .
Il Mio Problema
iPad 4th Gen WiFi with a broken front glass.
La Mia Riparazione
The instructions were great except that for some reason, they assumed that I would be replacing an intact glass panel. Mine was broken in 4 lines, and every time I got to another break, it would shatter down to powdered glass and glue (Yes I know it is 3M . . .
Mostra di più
