P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA - ESD Safe / New
11,99 US$
11,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
This P5 pentalobe screwdriver from Moody Tools is made in USA and features an ESD safe handle with a swivel top, and a double ended reversible pentalobe tip.
Storie di Riparazione
Il Mio Problema
battery was dying and had "service battery" alert in notifications panel
La Mia Riparazione
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
Il Mio Problema
Needed more RAM memory to upgrade to High Sierra OS.
La Mia Riparazione
Great.
Il Mio Consiglio
Make sure you hav the correct RAM memory because there are various types.
Il Mio Problema
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
La Mia Riparazione
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
Il Mio Problema
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
La Mia Riparazione
Everything went without a hitch. Thank you!
Il Mio Consiglio
Follow directions. Carefully unplug and reconnect battery.
Il Mio Problema
After five years the battery had cycled hundreds of times and was showing a need for service...
La Mia Riparazione
The swap was quick and easy... less than 20 minutes... great repair guide and product.
Il Mio Consiglio
ifixit.com should always be the first place you try.... great advice and solid products...
Il Mio Problema
Original Logic Board had failed
La Mia Riparazione
Repair went without a hitch.
Il Mio Consiglio
Follow the instructions!
Il Mio Problema
Trackpad kept drawing squares
La Mia Riparazione
Good.
Il Mio Consiglio
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
Il Mio Problema
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
La Mia Riparazione
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
Il Mio Problema
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
La Mia Riparazione
My biggest problem was that I didn't even know whic . . .
Il Mio Problema
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
Mostra di più
