Heavy-Duty Spudger
  • Heavy-Duty Spudger
  • 360°
360
Heavy-Duty Spudger
4,99 US$
4,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Poke and prod like you mean it.
  • Thicker variant of the official "black stick" that Apple Certified Technicians use to repair Apple computers.
  • 6" long antistatic nylon probe with one flat end and one pointed end.
  • Flat end can be used to disconnect connectors, remove thermal paste from heat sinks, pry off components, or aid in soldering.
  • Pointed tip is handy for unlocking ZIF connectors and poking your siblings.
Storie di Riparazione
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
Il Mio Problema
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
La Mia Riparazione
It went smooth, thanks to iFixit guides, videos, and tools
Il Mio Consiglio
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
Il Mio Problema
Battery would last about 4 hours from a full charge.
La Mia Riparazione
super simple, took about 45 minutes from opening ifixit.com to turning the phone on again.
Il Mio Consiglio
get good tools from ifixit first, they made all the difference.
Il Mio Problema
My battery was draining very fast when it got to 30% and the lighting connector was failing
La Mia Riparazione
The repair took about 3 hours in two sessions. The last step of the lighting connector assembly replacement guide was missing the step at the end to separate the microphone cable from the plastic microphone i . . .
Il Mio Problema
Got my old iPhone 5 back in shape to let the kids share
La Mia Riparazione
Piece of cake. I have repaired a couple of other phones (with iFixit's help!) so I knew what to expect.
Il Mio Consiglio
Follow the online guides! They tell you how to go and what to expect. I prefer the text with pictures, but there are videos too.
Il Mio Problema
My 18-month-old launched her Mom's iPhone 6 in the toilet, and then started crying, haha. I was at work when it happened, but Mom said that when she pulled it out of the toilet, she tried to turn it off but wasn't able to - and then she said it got hot... really hot. So, I figured that the battery . . .
Il Mio Problema
WiFi would work when MacBook was cold then stop later
La Mia Riparazione
Great! It's working again and the instructions on iFixIt's web site were perfect.
Il Mio Consiglio
I, for some reason, always considered Macs untouchable for repair even though I've routinely opened and fixed Windows PCs for years. That is gone! Macs are fixable! W . . .
Il Mio Problema
Battery was original and only charging to 67% of original capacity. Mac Superstore wanted $150.00 for replacement. With iFixit instructions and their excellent pentalobe driver, I did the replacement in 30 minutes, for a total of $75.00 including the battery.
La Mia Riparazione
The repair was without any issues. The iF . . .
Il Mio Problema
Computer refused to boot which was narrowed down after many other suggested remedies to a defective power supply. Replacing the power supply was not something that I had ever done before. But with the very detailed description given by Chris Green led me to a successful disassembly and removal of th . . .
Il Mio Problema
Only had one ear bud (also one speaker when using accessory on car radio).
La Mia Riparazione
One hour had iPod apart,changed out earphone jack and battery (figured y not while I had it apart) and back together.
Il Mio Consiglio
Plastic separaters weren't really used,small putty knife,metal AND plastic spudgers are a must. 00 Phillips s . . .
Il Mio Problema
Battery 6+years old, finally required a nonstop plug in charge. Basically, a desktop laptop. Slow and lots of beach balls was a normal function.
La Mia Riparazione
So, I scouted this iFixit site and logged it for later. After reading many reviews. I was sold on the battery for sure. The information was spot on. Many re . . .
Mostra di più
