PowerBook G4 Aluminum 15" Optical Drives
Replacement parts for your PowerBook G4 Aluminum 15" model to fix your broken computer!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Scegli il tuo modello di PowerBook G4 Aluminum 15":
Parti che funzionano con PowerBook G4 Aluminum 15":
Informazioni Dispositivo
The Aluminum 15" PowerBook was Apple's offering to fill the void between the small 12" and huge 17" Aluminum Powerbooks.
Two RAM slots can be stuffed with PC2700 RAM in these machines (except for the 1.67 GHz High-Res) for a memory boost. If you need more headroom, any 9.5mm ATA hard drive will fit in 15" Aluminums.
Sadly, the most commonly-faulty part in these notebooks are the RAM slots. If one or more of your RAM slots does not work, the logic board must be replaced to expand RAM. We carry a full variety of logic boards, depending on your model. Check out our Aluminum 15" troubleshooting guide for further help. We carry parts to restore your machine to working order!
