MacBook Unibody (A1278) Replacement Battery
  • MacBook Unibody (A1278) Replacement Battery
  • 360°
360
99,99 US$
99,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Replace a dead or otherwise malfunctioning battery in your MacBook Unibody (Model A1278) laptop computer with an aftermarket replacement battery.
Compatibilità
Compatibilità
  • MacBook 13" Unibody A1278 2 GHz and 2.4 GHz
Specifiche
Specifiche
Part #:
661-4817
Model #:
A1280
Watt Hours:
45 Wh
Voltage:
10.8 V
Milliamp Hours:
4170 mAh
Manufacturer:
Aftermarket
Compatibilità
Storie di Riparazione
Avatar utente
Il Mio Problema
The old battery was OLD... and not holding a charge.
La Mia Riparazione
Easy. This model (2008 aluminum) is designed for having the user replace the battery.
Il Mio Consiglio
None needed...
Avatar utente
Il Mio Problema
Old battery (original) had gotten swollen (interfered with trackpad) and it didn't hold a charge.
La Mia Riparazione
I opened the back (push on the simple lever/tab, pull off the panel) and inserted the new battery. I replaced the panel and it was done. Easy!
Battery was partly charged. I let it charge fully overnigh . . .
Avatar utente
Il Mio Problema
La batterie d'origine était fatiguée après huit ans devons et loyaux services
La Mia Riparazione
Très facilement, ce MacBook a été bien conçu sur ce plan en tous les cas.
Il Mio Consiglio
Je ne peu que remercier ifixit pour ses services de qualité.
Avatar utente
Il Mio Problema
My cat walked on my Mac-book and it crashed on the floor.
The screen broke in the meddle and the Apple store didn't want to repair it because too old (for them).
La Mia Riparazione
I fixed it easily following the photo-sequence of iFixit web site,
However I suggest two improvements:
1. It's not necessary to use the Hea . . .
Avatar utente
Il Mio Problema
Declining battery power for years. I've had this Macbook for almost seven years, and one battery charge would last 45 minutes.
La Mia Riparazione
The repair went so easily, I wish I'd done it earlier. It took 4-5 minutes tops.
Il Mio Consiglio
If your Macbook A1278 battery needs to be replaced, I would go ahead and do it. It's so easy.
Avatar utente
Il Mio Problema
My battery was dying. After 6 years of loyal service.
La Mia Riparazione
So easy. The early MacBook made it easy for the battery to be replaced. Happy and I think this MacBook can last me one or two more years. Time to start saving up for the next one =)
Il Mio Consiglio
Take care of your electronics equipment (name it!). It'll save you . . .
Avatar utente
Il Mio Problema
My Macbook unibody alu, late 2008, has a good 6 year on the back. A few years ago, i changes the HDD and screen unit, since it was going bad. Now the fan was started to sound like a jet engine and it was running slow, plus the battery only lasted an our.
La Mia Riparazione
I Ordered a new SSD, plus a dummy for my Supe . . .
Avatar utente
Il Mio Problema
Basically, because I was bored with the old system so I upgraded everything and I finally had the time - literally jumped from snow leopard to yosemite! It started with installing higher ram then figured out it was easy enough to install not just a new hard drive but a dual one. Thanks to you guys w . . .
Avatar utente
Il Mio Problema
Cracked screen of course
La Mia Riparazione
The repair went well all the way until I tried to use the home button on the new display assembly only to find that it wouldn't depress, which made me depressed.
So I opened it up and the button would depress. Clicked it back in and it would work with needing to be depressed . . .
Avatar utente
Il Mio Problema
Battery needed to be replaced (out dated)
La Mia Riparazione
very well
Il Mio Consiglio
if you live in the us buy from Amazon.com. I live in Saudi and It was the only way to import.
Mostra di più
