Aggiusta la tua roba
Diritto alla Riparazione
Store
MacBook Pro 15" (Models A1150/A1211) Display Inverter
  • MacBook Pro 15" (Models A1150/A1211) Display Inverter
14,99 USD
14,99 USD
Dettagli Prodotto
Descrizione
Descrizione
There is no better time than now to repair a damaged Display Inverter!
Includes just the inverter board.
Compatibilità
Compatibilità
  • 1.83, 2 or 2.16 GHz (Model A1150) 15" MacBook Pros
  • 2.16 or 2.33 GHz (Model A1211) 15" MacBook Pros
Specifiche
Specifiche
Part #:
922-7191
Compatibilità
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Storie di Riparazione
Avatar utente
Il Mio Problema
The display in my MacBook Pro (Early 2006 - intel core duo) would work for a random amount of time after booting the machine and then flicker and go out. Seemed like the backlight was working but the inverter had failed.
La Mia Riparazione
I received the inverter and followed the instructions. After putting everything . . .
Avatar utente
Il Mio Problema
The LCD backlighting died due to bad inverter.
La Mia Riparazione
Great guide with the exception on the referenced Phillips head bit, PH00. I found that the J00 bit was a much better fit than the referenced PH00.
Il Mio Consiglio
It's alive again ;-)I found that the J00 bit was a much better fit than the referenced PH00.
Avatar utente
Il Mio Problema
Screen on macbook pro was very dim. I could see the picture but the screen would not brighten. After reading some other forums I decided the display inverter was the problem.
La Mia Riparazione
It was a pretty easy repair following all of the steps. It took about 45 mins to get the new part in and the machine put back . . .
Avatar utente
Il Mio Problema
My friend needed his laptop asap for a gig. Decided to start with the cheapest part first.
La Mia Riparazione
Repair didn't go as plan. i suspected it needed more parts than just the inverter board. unfortunately replacement the inverter didn't fix the issue.
Il Mio Consiglio
80% of the time first generation MacBook pro 15 Core2Duos u . . .
Avatar utente
Il Mio Problema
I could not see any images or my artwork after turning on my MacBook Pro 15. Also finding out that it would cost too much to repair at the place I have my mac fixed. So I searched online and found your website. After procrastinating for three months, I decided to get my MacBook Pro running again. F . . .
Avatar utente
Il Mio Problema
Cheaper than a repair
La Mia Riparazione
It would have been easyer if I was under 70 years old!
It took about 2 hours.
Il Mio Consiglio
I would advise not trying this unless, like me, you have spent the last ten years of your retirement building and repairing computers.
P.S. 45 years as a maintainence machinest.
Avatar utente
Il Mio Problema
The MacBook Pro was seriously thrashed. It was dropped and dented, the front bezel was broken at both lower side and held together with lots of tape, and the screen was falling apart and did not light up. There was a ghost image and I was able to connect a second screen and get the screen set to Mir . . .
Mostra di più
