Aggiusta la tua roba
Diritto alla Riparazione
Store
Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" Retina MacBook Pro 15" Touch Bar Mid 2017 Case Components
Store
Grab a toolkit for your MacBook Pro 15" Touch Bar Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Pro 15" Retina (Late 2016-2019) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
Da 95,99 USD
MacBook Pro 15" Retina (Late 2016-2017) Upper Case / A-Stock / Dark Gray
Replace a scratched or dented upper case or malfunctioning keyboard compatible with a 2016 or 2017 model 15" MacBook Pro with Retina Display.
Da 127,99 USD
MacBook Pro 15" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 15" MacBook Pro with Retina Display.
9,99 USD
MacBook Pro 15" Retina (Late 2016-2019) Trackpad / New / Dark Gray
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
Da 59,99 USD
MacBook Pro 15" Retina (Late 2016-2019) Hinge Covers
Replace the plastic covers for the display hinges.
Da 0,99 USD
MacBook Pro 15" Retina (Late 2016-2019) Headphone Jack Cable Bracket
Replace a bent or missing bracket securing the headphone jack cable connector to the logic board in a 2016 to 2019 model 15" MacBook Pro with Retina Display.
Da 1,99 USD
MacBook Pro 15" Retina (Late 2016-2019) Display Cable Bracket
Replace bent or missing metal brackets securing the display cable in a 2016 to 2019 model 15" MacBook Pro with Retina Display.
Da 2,99 USD
MacBook Pro 15" Retina (Late 2016-2017) Upper Case Assembly / A-Stock / Dark Gray
Replace an upper case, keyboard, battery, and touchbar in your 2016 or 2017 model 15 inch MacBook Pro Retina laptop.
Da 319,99 USD
MacBook Pro 15" Retina (Late 2016-2017) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
9,99 USD
MacBook Pro 15" Retina (Late 2016/2017) Display Lower Edge Bezel Bracket
Replace a bent or damaged metal bracket that backs up the bezel at the bottom edge of the display assembly in a Late 2017 or 2017 model 15" MacBook Pro with Retina disp...
12,99 USD
Visualizzazione prodotti 1 - 10 di 11
Informazioni Dispositivo
Released in June 2017 as model A1707, this MacBook Pro features Kaby Lake processors up to the 2.9GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.9GHz.
The most common repairs with the 15" MacBook Pro Retina Mid 2017 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2017 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" Mid 2017 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2017 repair guides for step-by-step instructions on how to make the fix.
