MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • 360°
360
209,99 USD
209,99 USD
Dettagli Prodotto
Descrizione
Descrizione
Replace the 2.4 GHz logic board in your MacBook Pro 13" Unibody (Mid 2010) laptop and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Compatibilità
Compatibilità
  • MacBook Pro 13" Unibody A1278 Mid 2010
Specifiche
Specifiche
Part #:
661-5559
Model #:
A1278
Speed:
2.4 GHz
GPU:
NVIDIA GeForce 320M
Compatibilità
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
Storie di Riparazione
Avatar utente
Il Mio Problema
My MacBook Pro was suffering from the same Graphics problem as many others have experienced.
La Mia Riparazione
I followed the instructions to take out the faulty Logic Board. Then I installed the replacement from iFixIt, with a little bit of thermal paste. Got it all screwed back together and was done in 25 Minutes. . . .
Avatar utente
Il Mio Problema
The logic board failed due to my daughter spilling milk on it. I tried to clean the board but the lactic acid managed to eat away some of the thin traces.
La Mia Riparazione
I ordered a replacement from iFixIt, removed the old board and installed the new one. The system booted and everything worked as expected. So f . . .
Avatar utente
Il Mio Problema
My computer’s logic board stopped working, needed to be replaced.
La Mia Riparazione
The repair was actually pretty easy and I felt proud of myself for the repair... and thankful for iFix :)
Il Mio Consiglio
Always be curious (but cautious)! There’s so many things you can do on your own and save money if you take the time to researc . . .
Avatar utente
Il Mio Problema
Broken RAM sloth, so the MacBook was working a bit slow.
La Mia Riparazione
It went very well. The guide I used was very helpful and made the repair very easy! :)
Il Mio Consiglio
If you just follow the guide everything goes smoothly! :)
Avatar utente
Il Mio Problema
A few weeks ago my Macbook Pro started malfunctioning and gave me a blank white screen with a flashing folder and a question mark. I was unsure what this was and after some online research I figured it may be my hard drive. I installed a new hard drive but my Mac wouldn’t see it after going into r . . .
Avatar utente
Il Mio Problema
One drop or water got to the logic board
La Mia Riparazione
simple replacement
Il Mio Consiglio
keep Mac away from ANY source of moisture
Mostra di più
