Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo D-link DI-524, usa il nostro manuale di assistenza.
  1. D-link DI-524 Teardown, Overview: passo 1, immagine 1 di 3 D-link DI-524 Teardown, Overview: passo 1, immagine 2 di 3 D-link DI-524 Teardown, Overview: passo 1, immagine 3 di 3
    • This is the router, in all of its 12 year old glory.
  2. D-link DI-524 Teardown, Opening it up: passo 2, immagine 1 di 3 D-link DI-524 Teardown, Opening it up: passo 2, immagine 2 di 3 D-link DI-524 Teardown, Opening it up: passo 2, immagine 3 di 3
    • First of, remove the antenna by simply unscrewing it.
    • With that done, flip the router over and remove the 2 screws marked out in orange (pic 2).
    • Then simply flip the router back over and lift up the top plastic.
  3. D-link DI-524 Teardown, Removing the board: passo 3, immagine 1 di 3 D-link DI-524 Teardown, Removing the board: passo 3, immagine 2 di 3 D-link DI-524 Teardown, Removing the board: passo 3, immagine 3 di 3
    • With the plastic removed, we get a look at the board itself. Now remove the two other screws at the back (also marked out in orange).
    • Before being able to lift the whole board out, you will also have to unscrew a nut where the antenna was attached to. This can easily be done with a pair of pliers.
    • With that done, simply pull the connector out and lift the border 'up and out'.
  4. D-link DI-524 Teardown, The chips: passo 4, immagine 1 di 3 D-link DI-524 Teardown, The chips: passo 4, immagine 2 di 3 D-link DI-524 Teardown, The chips: passo 4, immagine 3 di 3
    • This is simply a better look at the board chips. If anone reading this knows specifically what they are, feel free to comment and I will add the information.
    • (There is also one more chip but Ifiixit allows only 3 pictures)
  5. D-link DI-524 Teardown, The lone metal clip: passo 5, immagine 1 di 2 D-link DI-524 Teardown, The lone metal clip: passo 5, immagine 2 di 2
    • The last piece of the router is this small metal clip here. Simply pull it up.
  6. D-link DI-524 Teardown, Thats it!: passo 6, immagine 1 di 1
    • You have successfully taken apart a D-link DI-524.
    • I was unable to remove anything more from the mother board as it is all soldered on.
Imad Knight
Membro da: 07/11/16
1.429 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,698
