Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Proximity sensor is STILL not working
I bought this phone off eBay knowing that the camera doesn't work and it came without a screen... So I basically replaced everything in it... Including the camera to see if it would work (it didn't ) , the one issue that has always annoyed me greatly is the proximity sensor, it's so annoying the way it doesn't black out when I'm making a call and I always hit the mute button with my face.
I have even bought the little sticker that says it fixes the problem but it still does nothing . I'm also on the latest firmware 5.1.1
I also tried using scotch tape to cover up the sensor then coloured it with black marker .
Nothing has worked . I've also tried completely replacing the proximity cable twice and still nothing , any ideas ? I'm on the verge of selling this if I can't fix it, thanks
Questa è una buona domanda?
Punteggio 1
1 Commento
been having the same problem, tried different pieces. works with an original like a charm. what is wrong with these sensors? original screen, original small filter and still no fix...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
bump
Punteggio 0
Aggiungi la tua risposta
Robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 611
