Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Trackpad replacement without keyboard replacement
Can the trackpad be replaced without replacing the keyboard? I have a broken trackpad and can't seem to find a part number for it. My mac is a MacBook Unibody Model A1278.
Thank You
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
6 Risposte
Risposta Più Utile
Yes it can! Your part number is 922-9014. You will, however, need a tri-wing screw driver to replace it. Plugging that part number into Google will lead you to the part.
Good luck!
Punteggio 5
Thank You for responding my post. I found the part using the part number you provided.
Punteggio 0
1 Commento:
Great! I'm glad you found what you needed!
da
I have a late 2008 model Macbook 5,1 aluminum case version. Is this a A-1278? I have a defective trackpad on the unit and need a replacement. Is the part number 922-9014 correct? Thanks, Knut Holzer
Punteggio 0
Have the same question as above: also have a late 2008 model MacBook 5,1.
Punteggio 0
Same here. Would love to know.
Punteggio 0
1 Commento:
These old questions rarely get looked at. Asking a new question brings better results and new things may have been learned in the last year and half.
da
http://www.everymac.com/ultimate-mac-loo...
Yes, they are all the same machine.
Punteggio 0
Aggiungi la tua risposta
avelez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 10,747
