Salta al contenuto principale
iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Questa è una buona domanda?
Punteggio 1
1 Commento
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
Punteggio 0
2 Commenti:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
da
I can see you!
da
Aggiungi la tua risposta
Ben Eisenman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,536
