Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Remove or leave Film on LCD + Digitizer?
Hello everyone,
I'm rather new with replacing LCD's, but I managed to do one yesterday. For some reason I noticed a back film on the LCD + Digitizer looking like this:
Click photo!
Do I have to remove this one or not?
Greetings,
Mittchel
Questa è una buona domanda?
Punteggio 2
1 Commento
Yes you must remove it or the screen won't work. I experienced this with a new iPhone 6 screen where the apple logo just kept flashing and would not respond to a reset via iTunes. Such a simple oversight which cost me hours of unnecessary work!!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yes, remove this protective plastic sheet right before you install the Front Screen. Often there is a tab to help remove it like in your photo. Some Screens don't have the tab on the plastic, but you still remove the plastic sheet.
Punteggio 4
8 Commenti:
Thanks. I wasn't sure, because in most videos they don't remove it. By the way.. does NOT removing this film this problem: Help needed! Strange colors on screen
Or is that something else?
da
So i tried to do the same but when i pulled it instead of the film coming off it pulled the whole thing off.. Is there any way i can fix this? Email me at corygandy@hotmail.com if you can...
da
Please answer the query of Mittchel. Does not removing the back film cause any problems?
da
Before assembling, I hooked up my new screen to test it. The film was still on the back and it worked fine. Digitizer fine too. But remember the phone can get pretty hot in the sun so it is probably best to remove the film so it doesnt melt inside the phone. I believe the film is even put there so that debris doesnt stick to the metal foil berore it is installed. That way it can conduct heat away better. I'm just guessing about that though.
da
Oh BTW this was an iphone 4.
da
Mostra altri 3 commenti
i have this same issue, i didn’t remove the film on my iPhone X screen replacement, now suffer random black screen while using the device most commonly noticed it will happen when changing orientation on my iPhone (Literally not orientation lock)
Punteggio 0
Aggiungi la tua risposta
Mittchel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 37
Tutti i Tempi: 25,821
