Why is my fan always running fast?
I have a problem. My CPU ist working and my fan always running fast? The temperature is ok?!? Can you help me???
Questa è una buona domanda?
The fans run to cool the CPU when you're working it hard (videos, games and the like). To check the temperature you need to use a 3rd part fan application there are several out there.
Some steps to try before replacing the logic board if you have a bad temperature sensor. Be sure to purchase the proper tools to open your laptop - every job is easier when you have the right tools.
If this answer was helpful please remember to mark it accepted.
Thank you for fast answer....
The problem is, the fan is running fast when i turn it on!
The temperature is good! The CPU system is high?!? Why??
A bad temperature señor could be the likely cause this. - Use the second link above for more information.
whenever my computer is running fast I open it and clean ALL dust out of it,
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,782
