Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How do I replace the broken logic board of the MacBook
my macbook is white 13" and has a broken logic board which needs replacemeny
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Start by properly and completely identifying your mac. Then study the guide and see if you are capable of this DIY (this is a major task). Order the proper tools (every job is easier when you have the proper tools) and replacement logic board.
If this answer was helpful please remember to mark it accepted.
Immagine Replace a 2 GHz logic board (motherboard) compatible with the MacBook Core Duo. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out.
Prodotto
MacBook Core Duo 2 GHz Logic Board
$99.99
Punteggio 0
Aggiungi la tua risposta
henry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 699
