Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
Domanda Chiusa
Black Display After Repair
Hello.
I Changed The Display-Assembly (Display and Glass), now the iPhone 3G Screen is Black.
1) Reboot (Hold and Home) doesn't work
2) Restore (Itunes 3.1.2) doesn't work
3) Re-Disassembly with replacing Battery doesn't work.
I-Phone is Running, Vibration OK, Sounds ok, ..
If i Take a Screenshot of iPhone it's black.
What can a do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This is what i would suggest.
Take it apart, down to removing the logic board. Sometimes when you recontact the logic board and the battery it seems to work.
I wouldnt advise it but you could just remove the four screws on the right side of the logic board and then tilt it off the battery connector leads in order to recontact the logic board. I wouldn't advise it because you could bend or snap your board, but this is the way i did it.
Sometimes its not the front assembly ribbons but the other ribbons or the contact between the board and battery.
If that does not work let me know and i will suggest another way.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,209
