Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
MacBook key board not working
coffee was spilled on my keyboard, now keyboard will not work, I know not smart! Any how last four of S#J0P1 the specs 2.4/2x1g/160/sd-dl:white.(EMC no:2242) I want to replace the keyboard but can not locate the correct keyboard, (doing this for a friend) the mouse does still work but not the keys everything else is as it should be, removed keyboard once and cleaned the ribbion connector did not help.. Any and all help to solve this issue is greatly appreciated.
Harold
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Follow the advice here. Simply wiping off the ribbon cable will not clean, nor solve the myriad problems that can result from spilling coffee into a laptop. To locate parts you need exact make/model identification information "mac 13.3 laptop" just isn't enough.
If this answer was helpful please remember to return an mark it Accepted.
Punteggio 0
Aggiungi la tua risposta
Harold sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 736
