Why there is no injection
Not starting due to fuel injection
Questa è una buona domanda?
If your Mahindra XUV500 is not starting and you've determined there is "no injection" (meaning fuel isn't reaching the cylinders), the issue usually lies in the Common Rail Direct Injection (CRDe) system’s ability to build or sense pressure.
The ECU will not signal the injectors to open unless it sees a specific minimum pressure in the fuel rail. Here are the most likely reasons for a "no injection" state:
The high-pressure pump (FIP) is responsible for pushing diesel into the rail at massive pressures.
The ECU relies on the Rail Pressure Sensor to know if there is enough fuel to start.
The XUV500 is sensitive to air bubbles in the fuel lines.
The ECU needs to know exactly where the engine is in its rotation to timed the injection.
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 34
Tutti i Tempi: 34
