Salta al contenuto principale
The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
My pc won't start at all
When I push the on button my desktop doesn't go on plus the power cable is plugged in perfectly
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @arielroar
When you try to start the PC what is the colour of the Power LED and is it flashing at all?
If it is flashing, this is an error code telling what the problem is.
Count the number of times it flashes before it pauses and starts to flash again, the same number of times.
Once you have counted the number of flashes go to p.255 → p.258 (267 → 270 of 345 pdf) in the maintenance and service guide to find it what it means
Punteggio 1
Aggiungi la tua risposta
Ariel ROAR sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 22
Tutti i Tempi: 22
