Salta al contenuto principale
Hewlett-Packard ha iniziato a produrre personal computer di tipo laptop nel 1993.
3330 Domande Visualizza tutte
Domanda Chiusa
Hp dv6 1308EL stuck on HP Invent screen
Hi all,
I've had a problem with my notebook.
I've unmounted it to change the thermal paste on CPU and GPU, and now when I power it it gets stuck at the HP Invent screen for a loong time.
How can I fix it?
I've tried to change the thermal paste again, and it was ok.
I've resetted the CMOS
I've tried separately the two RAM cards
I've tried to boot it without the hdd
BUT nothing happened..
Even the BIOS screen, when I manage to get to it, it's veery slow, I can barely navigate in it..I've resetted the Bios settings, but still nothing..
Help me please, I'm going crazy!
And I forgot to tell that the first time I booted it, it worked fine and I used it for a few hours and it was going just fine!
After I restarted it, with no updates, it didn't boot anymore..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Slow BIOS navigation? Check that thermal paste again, sounds like overheating. If you are not sure what good thermal paste connection should look like, put some on a flat piece of metal, and smush it with another piece of metal. Also, check to make sure that your Heatsink os properly vented, and that dust particles are not blockin the airflow.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 744
