Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Domanda Chiusa
Changed antenna and now display is only grey
hi, I changed my antenna and now my display is only grey.... the phone itself works because when I charge it I can hear that I put the charging cable in.....
I think I don't have damaged anything because I often open an iphone...
Does anybody know which problem it could be??
Questa è una buona domanda?
Punteggio 0
1 Commento
I checked everything and all is fine... I put it into dfu mode and restored it and now the display is white, once it had a lot of coloured stripes, but now its only white.... Is it the diplay or any other problem??
And can I make sure that the iphone is OFF, without display?
Best regards
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the display is grey, then you put the LCD connector on wrong, or damaged the LCD. Open it up again and check the connectors, make sure the connector clicks in. Make sure the phone is OFF when doing so.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 444
