Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
Domanda Chiusa
IReccomendations to replace the Hdd
OK so I 've got my Imac EMC 2428. its got a seagate barracuda ST3500418AS inside it.
Can someone please tell me 1st what 1tb hdd to buy to upgrade. And 2nd what prep I need to do to the hdd before I physically replace it. ( I.E Firmware, Carbon Cloner and such)
Please I've reserched this a lot and I'm hearing a lot of horror stories. if you have this(Exact) machine and you've succesfully upgrade your hdd please tell me what you used and did.
Hopefully yours
James
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Presently your options are limited. Apple moved to an internal HD heat sensor and now uses a custom HD and SATA cable so you must use one of their HD's to replace what you have (the easy answer).
If you do use a 3rd party HD (which still will work your system) the fans will slowly step up into over drive as the thermo detection system can't figure out what your HD's temp is. To solve this people have gone to fan control software. But, it has limits, as it is then forcing the fans to go to a given speed and not using the internal thermo monitoring to vary the speed of the fans as needed given the heat generated within the system.
For now I would stick with an external HD and see what happens this year with Seagate and Maxtor offering compliant HD's.
Punteggio 1
Risposta Più Utile
Get an external HD you can boot from it and keep your internal as a backup, that's so much easier.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 731
