Replacing the 3.5mm headphone jack.
How can I replace the 3.5mm headphone jack?
What type of jack is used?
Or does it need to be replaced along with the motherboard?
Questa è una buona domanda?
Hello! I believe it is soldered to the motherboard on this model though I was unable to confirm this. (I am assuming it is similar to a G40 which I was able to confirm.) Before going straight to replacement I would try some troubleshooting steps.
If none of these work, it likely does need replacement, you can open the phone, remove the old 3.5MM jack and solder a new one on. I cannot find any info on which one is used unfortunately, or more specific instructions for this specific model.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 16
Tutti i Tempi: 16
