Salta al contenuto principale
Lenovo LOQ 15IAX9 con Intel i5-12450HX, GPU fino a RTX 4060, display FHD 144 Hz da 15,6″, fino a 32 GB DDR5, SSD PCIe Gen4, batteria da 60 Wh e I/O completo, inclusi HDMI 2.1 e USB-C.
How cleaning colling fans?
I want to clean my laptops fan
Questa è una buona domanda?
Punteggio 1
1 Commento
Clean colling fan
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
You can follow Lenovo's official guide in their Hardware Maintenance Manual to take of the lower chassis (see page 30).
Then you'll have direct access to the fan. You can remove the dust with a small brush, some pressured air, or if you are a bit careful you could use a vacuum cleaner on lowest setting. Note! That having the fans spinning a lot when blowing/sucking can be bad for them, so gently keep a finger on the fan to keep it from spinning.
Good luck!
Punteggio 2
Aggiungi la tua risposta
fun codm sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 89
Tutti i Tempi: 984
