Salta al contenuto principale
Questa è la versione da 8 pollici del più piccolo Fire 7. Include 1,5 GB di RAM, un processore più veloce e un display HD. Il Fire HD 8 è stato rilasciato il 7 giugno 2017.
Broken Battery Connector on Mobo
I recently purchased a replacement battery for my Kindle but during the installation process, I inadvertently broke the plastic foundation piece (female) on the motherboard. Is there any way to either replace this part, repair it (even a temporary workaround so I just turn on device and access the data) or access the data if I can't get it to turn on. Is there a way to turn on the device or access the folders without the battery? Any help or suggestions would be greatly appreciated!!!! I'm desperate at this point.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Your Kindle Fire HD 8 will not boot with only a charger — it needs a battery or a simulated battery. If the battery connector’s plastic housing broke, you can replace it or temporarily solder the battery wires directly to the motherboard pads long enough to turn on the device and extract your data. A microsoldering repair shop can perform a proper connector replacement if needed. If you send a photo, I can guide you exactly on what to do.
Punteggio 1
1 Commento:
Thank you very much for your quick and detailed response. How can I get a photo to you?
da Condividi
Aggiungi la tua risposta
rickenphoenix sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 26
Tutti i Tempi: 190
