Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Domanda Chiusa
Why is my digitiser uncalibrated after replacing it?
Iphone 3gs 16gb.
I replaced the digitiser and front glass (1 piece) put it back together, it detects my touches so is working, but thinks I am tapping about 1cm to the left of where I actually am tapping. Is there a way to calibrate the touchscreen like on many phones or have I done something wrong? I know this is a known issue, but there doesn't seem to be any up to date information or definite answer :( any help would be very appreciated as I'm doing it for a friend and I can't imagine them being 100% happy with this fix as only the outer glass was broken when they gave me the phone! thanks, max
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You either have a faulty digitizer or, more likely....
You have a faulty mainboard connector. The first iPhone I ever looked at was this way, and I needed to have the iPhone looked at. It ended up being that the connector could not be fixed to resolve the issue. Again, you are looking at a bad mainboard digitizer connector (#2). It may be fixable, but it may not be.
Best of Luck,
Punteggio 0
having same problem did you need a new glass?
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 630
