Salta al contenuto principale
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
Dištančna podložka pre VCR Sanyo VHR-3100EE
Dobrý deň potreboval by som dištančnú podložku pod pravú cievku na VCR Sanyo VHR-3100EE s vonkajším priemerom 6mm s vnútorným priemerom 3,1mm a hrúbkou 0,25/0,5mm kde by som ju zohnal prosím poradte mi aj nejaké fóra
Translation Slovak - English
Spacer pad for Sanyo VHR-3100EE VCR
Hello, I need a spacer pad for the right reel on a Sanyo VHR-3100EE VCR with an outer diameter of 6 mm, an inner diameter of 3.1 mm, and a thickness of 0.25/0.5 mm. Where can I find one? Please advise me on some forums.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@jaroslavmo15223 Sanyo part number for that is 411 109 190 and it does not look like it is readily available. Multiple other VCR's from Sanyo (VHR-770, VHR5418, VHR190E,Funai SVG220etc,.) are using the same washer. Maybe you can find a broken one of those and use it as a donor for your VCR. If not then I would suggest you have someone machine you the part out of 6mm stock. Or you could get something like this and file it down to size.
Translation
@jaroslavmo15223 Číslo dielu Sanyo pre tento diel je 411 109 190 a nevyzerá to, že by bol ľahko dostupný. Viacero iných videorekordérov od Sanyo (VHR-770, VHR5418, VHR190E, Funai SVG220 atď.) používa rovnakú podložku. Možno nájdete nejakú poškodenú a použijete ju ako náhradný diel pre váš videorekorder. Ak nie, odporúčam vám nechať si vyrobiť diel z 6 mm materiálu. Alebo si môžete kúpiť niečo ako toto a obrúsiť ho na požadovanú veľkosť.
Punteggio 1
10 Commenti:
Ďakujem oldturkey03 vedel by si mi povedať akú hrúbku dištančnej podložky by mala mať pravá a ľavá cievka sú rovnaké alebo každá cievka ma inú hrúbku?
da
@jaroslavmo15223 use something like the SM for the Sanyo Vhr310. The washer that you are needing, is listed here on page 16 as 4120158603 and shows 0.25mm thickness. It will also show you the rest of the drive mechanism which will be similar, if not even identical, to your drive.
Translation
@jaroslavmo15223 použite niečo podobné ako SM pre Sanyo Vhr310. Podložka, ktorú potrebujete, je uvedená na strane 16 pod číslom 4120158603 a má hrúbku 0,25 mm. Uvidíte tu aj zvyšok mechanizmu pohonu, ktorý bude podobný, ak nie identický, s vaším pohonom.
da
Ďakujem ti veľmi si mi pomohol ale pozeral som mechaniku Sanyo VHR-3100EE a Sanyo VHR-310 a nie je rovnaká je rozdielna a neviem aké sú hrúbky dištančných podložiek pre model Sanyo VHR-3100EE u ľavej a pravej cievky poradil by si mi ešte v tomto probléme
da
@jaroslavmo15223 Let me see if I can find the manual for your model. I do have multiples of the VHR series but need to check to see if the mechanism matches that of the 3100EE
@jaroslavmo15223 Skúsim nájsť návod k vášmu modelu. Mám viacero modelov zo série VHR, ale musím skontrolovať, či mechanizmus zodpovedá mechanizmu modelu 3100EE.
da
Mostra altri 5 commenti
Aggiungi la tua risposta
Jaroslav Molovčák sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 57
