Salta al contenuto principale
Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model numbers G9BQD, GA04851-US, GKWS6, GPJ41, and GZPFO.
After replacing screen, lock screen is extremely dim
After replacing my screen with the geniune part from iFixit on my Pixel 8 running Android 16 my lock screen brightness looks like it's set at it's lowest setting and extra dim. The brightness works fine while the device is unlocked, but the lock screen remains extra dim and dark. I have enabled screen wake on notifications, but even when notifications arrive, the lock screen stays extra dim while showing the notification.
I can't seem to find any setting that can control the lock screen brightness, so was wondering if anyone had any similar problems after replacing the screen? I also can't find any calibration option in settings that could help fix this issue.
Questa è una buona domanda?
Punteggio 0
1 Commento
After looking through some of the other issues I noticed that someone suggested the black sticker on the back of the screen also had to be removed:
Proximity sensor not working after replacing screen
It's not clear from the instructions that that black padding should have been removed.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Turns out I forgot to remove the black sticker on the replacement screen which was covering the proximity sensor. The lock screen now correctly adjusts brightness with ambient lighting. DOH!
Punteggio 0
Aggiungi la tua risposta
Klmn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 51
