Salta al contenuto principale
Una console portatile rilasciata da Valve. Lanciata sul mercato il 25 febbraio 2022.
SSD replacement and self-tapping screws
I've got a launch model Steam Deck and I'm considering swapping up from 256GB to 2TB on the internal SSD. I remember the initial Valve-provided video suggests not opening the Deck as that will likely disrupt the cooling airflow due to using self-tapping screws on the original case.
Should I be replacing the front and back panels at the same time if I want to replace the SSD, in order to avoid this potential cooling problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
When you open it up and finish working on it, spin the screws backward until they fall into place to avoid creating new threads. That will be suffienct for your case.
Punteggio 2
Aggiungi la tua risposta
Firehawke R sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 43
