Salta al contenuto principale
Suzuki’s AE50 was introduced in Canada in 1990, seemingly as a competitor to the popular Yamaha Jog and Honda Dio.
1 Domande Visualizza tutte
cant start the moped after been stored.
We have a 1991 suzuki AE50 moped, we removed the battery and had the moped stored for 4years now we charged the battery checked the spark plug but the moped wont start can you help as to the promblem Thank you ...
Questa è una buona domanda?
Punteggio 0
1 Commento
My motorcycle Suzuki sometimes doesn't star
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Theres a very good chance the carburettor is full of dried fuel. The metering jets are almost certainly plugged and not allowing any fuel through. If the motor spins and the plug sparks, but comes out bone dry you aren't getting any fuel to the engine. You need to remove the carb, strip it and clean it out, a workshop manual will run you through the procedure, either a Haynes or Clymer manual will do.
Its a pretty common thing to happen to bikes/scooters after a long layup.
Punteggio 2
2 Commenti:
+1 Big Pete:). Rita, on here for a general description on how to fix your moped. Here is the online parts list for your moped. Hope you enjoy your moped.
da
Will they start with out a battery or no
da
There is a vacuum type valve that the gasoline from the tank connects to and from there too the carb it also has a vent tube and a vacuum tube . This tends to stick it can be exersised by the vacuum line but is not that expensive just hard to get to. If you want to sell I need a front end for mine (i_byer2@hotmail.com)
Punteggio 1
Aggiungi la tua risposta
Rita sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,281
