Salta al contenuto principale
Repair guides and support for top and front loading Whirlpool brand washers.
Washing Machine Grinding Noise?
Help appreciated. My washer machine is making this horrible grinding noise during wash/ agitate cycles. I attached a video. Thanks!
Questa è una buona domanda?
Punteggio 0
2 Commenti:
@emilielaky what is the exact model number for your washer?
da
@oldturkey03 model number is HSWP1000M4WW there's also a serial number SF176616H. thanks!
da
Aggiungi un commento
1 Risposta
Grinding noise on a Whirlpool top-loader almost always comes from the drive components under the tub, not the motor itself. Based on the sound in your video, these are the two most common causes:
1. Worn agitate dogs (agitator “dogs” / cam kit)
If the noise happens during wash/agitate, the plastic dogs are stripped and slipping.
Cheap and easy fix — the top of the agitator comes off and the kit drops in.
2. Failing gearcase / clutch assembly
If the noise is heavier and continues through both wash and spin, the transmission gears or clutch are wearing out.
This creates a grinding/rumbling sound exactly like what you described.
Quick checks you can do:
Try spinning the agitator by hand — if it slips or clicks, it’s the dogs.
Tilt the washer back — look for oil leaking from the gearcase (a sure sign it’s failing).
If you can upload a 5–10 second close-up of the sound from the bottom of the machine, I can tell you which one it is for sure.
Punteggio 0
Aggiungi la tua risposta
Emilie Laky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 77
