Why doent my MacBook Pro work?
my screen stays on the spining pin wheel ,then a bar comes up, then it loads half way and shuts down
Questa è una buona domanda?
Either your system is corrupt or your flash drive is failing. Start up from your original system installation DVD, (hold down the C key when starting. Go to the second screen pull down menu to Utilities > Disk Utility. Select your hard drive icon in the left hand column and see if you can repair it. Reinstall the system if you have to.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 383
