Salta al contenuto principale
Repair and disassembly information for Samsung's S22 Ultra smartphone, released in February 2022.
What component is this and what does it do
Update (10/05/25)
Update (10/05/25)
Galaxy note 20 ultra motherboard
Questa è una buona domanda?
Punteggio 1
5 Commenti
The pic I posted is from a galaxy s22 ultra the capacitor broken off so the device boot and show the Samsung logo for some seconds and then goes black and power off. am looking a replacement capacitor. Can I get a replacement from another device motherboard like a galaxy note 20 ultra or any other device
da
[image|3791636][image|3791638][image|3791637]
da
My donor galaxy s22 motherboard. See pics
da
@blazeink what other boards do you have. I do not have the parts list for the S22 board.
da
Good morning. My galaxy s22 ultra wifi not working. I sent a pics of the issue but Bluetooth working find. Need you help in solving this issue [image|3850248]
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@blazeink that is reference designator C24042 which is a 120PF 10% 25V X7R capacitor in a 0603 package.
Update (10/05/25)
@blazeink that board does not have the same capacitors but it does have a 270PF capacitor which you can use. Replacement capacitors with a higher capacitance can be used for as long as the values are never lower than the original. It is C9126 To find it you will need to remove the EMI shield
and then you will find the capacitor in the location as outlined by the blue arrows.
Punteggio 0
11 Commenti:
Capacitors like that are typically used to smooth out fluctuations in the power inputs to various components; they're placed very close to whatever part they're protecting.
da
The pic I posted is from a galaxy s22 ultra the capacitor broken off so am looking a replacement can I get a replacement from another device motherboard like a galaxy note 20 ultra
da
@blazeink yes you can for as long as it has the same value. I am not sure why you would do that. These capacitors are a "dime a dozen " and really inexpensive. Now, if you have a board laying around that you want to use as a donor board, we will need to know exactly what board you have.
The capacitor is part of your battery circuit so yes, it could be causing the issue.
da
I have a galaxy s22 donor board
da
I all so have other samsung boards
da
Mostra altri 6 commenti
Vedi il contenuto dell'immagine:
Punteggio 0
2 Commenti:
Wifi not working
da
@blazeink same phone? What have you tried? What have you checked?
da
Aggiungi la tua risposta
blaze ink sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 133
