Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
Stripped screw and its removal
Do you think this screw can be removed by using the extractor tool set or should I just go for the drill solution? I've tried rubber band before and it didn't work and I really need to get into the joycon to fix my drift and lock mechanism. Thanks for the answers!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
IV had the same problems with the 3tri screws I used a tiny small metal drill bit like for a Dremel tool and then used a small easy out bit it turns and bits into the striped screws hole it'll remove it nicely hope it helps.
Punteggio 0
Aggiungi la tua risposta
soap sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 29
