Why my phone is not vibrating?
Phone not vibrating
Questa è una buona domanda?
@jacksongit53678 first check that the vibration is enabled in the Settings > Sounds and vibration menu for calls and notifications. After that restart the phone just in case there is a software issue.
If those steps did not resolve it then you can check the vibration motor by dialing *#0*# and select the Vibration test. That way you will know if it is the motor that has failed.
Since iFixit does not yet have a guide for this, use the one from here It was written in Spanish so use a browser that does the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 37
