Salta al contenuto principale
Repair information for MacBook Pro models with 14" displays, first released October 2021.
Disabling Haptics on trackpad
Hi, has anyone found a way to physically disable the Haptic actuator on the trackpad of the Macbook Pro M4? I am thinking about returning it unless I can find a way. The trackpad experience is awful because the haptics make the whole case rattle and feel tinny, even on the lightest setting.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
You might want to try this tool: https://github.com/shalamand3r/SlabPad
It’s a small utility that disables the Force Touch haptic feedback on MacBook trackpads, which can stop the rattly/tinny feeling while still letting you press to click. Might be worth trying before returning the laptop.
Punteggio 1
3 Commenti:
Of course look at GitHub for the answer!
da
This is SO helpful! Thank you! This is exactly the kind of app I was looking for. This solved the terrible, tinny haptic feeling.
da
So glad it helped!!!
da
I would recommend you bring the system to an Apple Store for them to checkout. It sounds like yours has a problem. It shouldn't cause the whole case to rattle or feel tinny.
So while one can kill it it's not someing I recommend as you would need to replace it to get it working again.
Punteggio 0
Aggiungi la tua risposta
Luke L sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 208
