Salta al contenuto principale
Samsung's robotic vacuum featuring Wi-Fi connectivity. Model number: VR2AM7070WS/AA.
Cyclone fan is not spinning
The little fan inside the dust bin isn't spinning, so debris isn't being pulled all the way into the bin. I tried turning it manually, but it's stuck in place. Does anyone know how to fix this issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You have to teardown, clean everything in fan section, and check the engine. If it's anchor is stuck you have to replace the engine. Otherwise cleaning from litter will help.
Punteggio 0
Aggiungi la tua risposta
Miss Behaves sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 24
